For nearly 30 years, ETABS has been recognized as the industry standard for Building Analysis and Design Software. Today, continuing in the same tradition, ETABS has evolved into a completely integrated building analysis and design environment. The system built around a physical object based graphical user interface, powered by targeted new special purpose algorithms for analysis and design, with interfaces for drafting and manufacturing, is redefining standards of integration, productivity and technical innovation.
The integrated model can include moment resisting frames, braced frames, staggered truss systems, frames with reduced beam sections or side plates, rigid and flexible floors, sloped roofs, ramps and parking structures, mezzanine floors, multiple tower buildings and stepped diaphragm systems with complex concrete, composite or steel joist floor framing systems. solutions to complex problems such as panel zone deformations, diaphragm shear stresses, and construction sequence loading are now at your fingertips.
ETABS is the solution, whether you are designing a simple 2D frame or performing a dynamic analysis of a complex high-rise that utilizes non-linear dampers for inter-story drift control.
