Model, Design and Optimized a Multi-Story steel Structure using ETABS
comment_55189
This 69-page book of seminar notes is handed out at our "From Start to Finish: Model, Design and Optimized a Multi-Story Steel Structure using ETABS" seminar. The book contains the example of a steel structure we walk through in our presentation. Starting with a .DXF import of an architectural grid, the manual finishes with the creation of output reports for submittal. This book also contains steel design examples using the ANSI/AISC 341-05 Steel Code. In these seminar notes, you will find descriptions, computer model definitions, and results for each of these examples.
http://www.csiberkeley.com/system//files/training-manuals/pdf/etabs-multistory-steel_0.pdf
Example Files:
http://www.csiberkeley.com/system/files/training-manuals/examples/steelstartfinsh.e2k
http://www.csiberkeley.com/system/files/training-manuals/examples/steelfloor.dxf
  • Vues 1.1 k
No posts to show
Rejoindre la discussion !
