✅ Accès total aux rubriques
✅ Téléchargements illimités
✅ Expérience sans publicité
✅ Veille actus, et tendances
✅ Veille offres d'emploi
✅ Veille conférences
✅ Stockage augmenté
✅ Badge PRO
✅ Messages privés et plus !
bonjour les techniciens,
je joindre ci dessous un livre de la construction métallique riche et trés util pour l'ingenieur et sourtout
avec pas mal d'exemples numiriques traités,
edition: fourth edition
auteurs: Barry Onouye et Kevin Kane
volume: 620 pages
taille: 36.9 Mo
format: Pdf
sommaire: 11 chapitres
langue: anglaise
CHAPTER 1 INTRODUCTION 1
1.1 Definition of Structure 1
1.2 Structural Design 2
1.3 Parallels in Nature 3
1.4 Loads on Structures 5
1.5 Basic Functional Requirements 9
1.6 Architectural Issues 11
CHAPTER 2 STATICS 15
2.1 Characteristics of a Force 15
2.2 Vector Addition 23
2.3 Force Systems 29
2.4 Equilibrium Equations: Two-Dimensional 61
2.5 Free-Body Diagrams of Rigid Bodies 74
2.6 Statical Indeterminacy and Improper Constraints 86
CHAPTER 3 ANALYSIS OF SELECTED DETERMINATE STRUCTURAL SYSTEMS 96
3.1 Equilibrium of a Particle 96
3.2 Equilibrium of Rigid Bodies 111
3.3 Plane Trusses 119
3.4 Pinned Frames (Multiforce Members) 153
3.5 Three-Hinged Arches 164
3.6 Retaining Walls 175
CHAPTER 4 LOAD TRACING 195
4.1 Load Tracing 195
4.2 Lateral Stability Load Tracing 231
CHAPTER 5 STRENGTH OF MATERIALS 251
5.1 Stress and Strain 251
5.2 Elasticity, Strength, and Deformation 267
5.3 Other Material Properties 274
5.4 Thermal Effects 289
5.5 Statically Indeterminate Members (Axially Loaded) 294
CHAPTER 6 CROSS-SECTIONAL PROPERTIES OF STRUCTURAL MEMBERS 300
6.1 Center of Gravity—Centroids 300
6.2 Moment of Inertia of an Area 311
6.3 Moment of Inertia of Composite Areas 318
6.4 Radius of Gyration 329
CHAPTER 7 BENDING AND SHEAR IN SIMPLE BEAMS 332
7.1 Classification of Beams and Loads 332
7.2 Shear and Bending Moment 337
7.3 Equilibrium Method for Shear and Moment Diagrams 340
7.4 Relationship Between Load, Transverse Shear, and
Bending Moment 346
7.5 Semigraphical Method for Load, Shear, and Moment Diagrams 348
CHAPTER 8 BENDING AND SHEAR STRESSES IN BEAMS 365
8.1 Flexural Strain 366
8.2 Flexural (Bending) Stress Equation 368
8.3 Shearing Stress—Longitudinal and Transverse 382
8.4 Development of the General Shear Stress Equation 384
8.5 Deflection in Beams 402
8.6 Lateral Buckling in Beams 419
8.7 Introduction to Load Resistance Factor Design (LRFD) 422
CHAPTER 9 COLUMN ANALYSIS AND DESIGN 438
9.1 Short and Long Columns—Modes of Failure 439
9.2 End Support Conditions and Lateral Bracing 446
9.3 Axially Loaded Steel Columns 456
9.4 Axially Loaded Wood Columns 474
9.5 Columns Subjected to Combined Loading or Eccentricity 487
CHAPTER 10 STRUCTURAL CONNECTIONS 494
10.1 Steel Bolted Connections 495
10.2 Welded Connections 519
10.3 Common Framing Details in Steel 531
CHAPTER 11 STRUCTURE, CONSTRUCTION, AND ARCHITECTURE 538
11.1 Initiation of Project—Predesign 539
11.2 Design Process 540
11.3 Schematic Design 542
11.4 Design Development and Construction Documents 544
11.5 Integration of Building Systems 555
11.6 Construction Sequence 561
11.7 Conclusion 563
lien de télechargement:
Lien supprimé (contenu ayant des droits d'auteur)
bonne lecture,
