Posté(e) Octobre 28, 201113 a comment_60438 bonjour les techniciens, je joindre ci dessous un livre de la construction métallique riche et trés util pour l'ingenieur et sourtout avec pas mal d'exemples numiriques traités, edition: fourth edition auteurs: Barry Onouye et Kevin Kane volume: 620 pages taille: 36.9 Mo format: Pdf sommaire: 11 chapitres langue: anglaise CHAPTER 1 INTRODUCTION 1 1.1 Definition of Structure 1 1.2 Structural Design 2 1.3 Parallels in Nature 3 1.4 Loads on Structures 5 1.5 Basic Functional Requirements 9 1.6 Architectural Issues 11 CHAPTER 2 STATICS 15 2.1 Characteristics of a Force 15 2.2 Vector Addition 23 2.3 Force Systems 29 2.4 Equilibrium Equations: Two-Dimensional 61 2.5 Free-Body Diagrams of Rigid Bodies 74 2.6 Statical Indeterminacy and Improper Constraints 86 CHAPTER 3 ANALYSIS OF SELECTED DETERMINATE STRUCTURAL SYSTEMS 96 3.1 Equilibrium of a Particle 96 3.2 Equilibrium of Rigid Bodies 111 3.3 Plane Trusses 119 3.4 Pinned Frames (Multiforce Members) 153 3.5 Three-Hinged Arches 164 3.6 Retaining Walls 175 CHAPTER 4 LOAD TRACING 195 4.1 Load Tracing 195 4.2 Lateral Stability Load Tracing 231 CHAPTER 5 STRENGTH OF MATERIALS 251 5.1 Stress and Strain 251 5.2 Elasticity, Strength, and Deformation 267 5.3 Other Material Properties 274 5.4 Thermal Effects 289 5.5 Statically Indeterminate Members (Axially Loaded) 294 CHAPTER 6 CROSS-SECTIONAL PROPERTIES OF STRUCTURAL MEMBERS 300 6.1 Center of Gravity—Centroids 300 6.2 Moment of Inertia of an Area 311 6.3 Moment of Inertia of Composite Areas 318 6.4 Radius of Gyration 329 CHAPTER 7 BENDING AND SHEAR IN SIMPLE BEAMS 332 7.1 Classification of Beams and Loads 332 7.2 Shear and Bending Moment 337 7.3 Equilibrium Method for Shear and Moment Diagrams 340 7.4 Relationship Between Load, Transverse Shear, and Bending Moment 346 7.5 Semigraphical Method for Load, Shear, and Moment Diagrams 348 CHAPTER 8 BENDING AND SHEAR STRESSES IN BEAMS 365 8.1 Flexural Strain 366 8.2 Flexural (Bending) Stress Equation 368 8.3 Shearing Stress—Longitudinal and Transverse 382 8.4 Development of the General Shear Stress Equation 384 8.5 Deflection in Beams 402 8.6 Lateral Buckling in Beams 419 8.7 Introduction to Load Resistance Factor Design (LRFD) 422 CHAPTER 9 COLUMN ANALYSIS AND DESIGN 438 9.1 Short and Long Columns—Modes of Failure 439 9.2 End Support Conditions and Lateral Bracing 446 9.3 Axially Loaded Steel Columns 456 9.4 Axially Loaded Wood Columns 474 9.5 Columns Subjected to Combined Loading or Eccentricity 487 CHAPTER 10 STRUCTURAL CONNECTIONS 494 10.1 Steel Bolted Connections 495 10.2 Welded Connections 519 10.3 Common Framing Details in Steel 531 CHAPTER 11 STRUCTURE, CONSTRUCTION, AND ARCHITECTURE 538 11.1 Initiation of Project—Predesign 539 11.2 Design Process 540 11.3 Schematic Design 542 11.4 Design Development and Construction Documents 544 11.5 Integration of Building Systems 555 11.6 Construction Sequence 561 11.7 Conclusion 563 lien de télechargement: Lien supprimé (contenu ayant des droits d'auteur) bonne lecture,
Novembre 1, 201113 a comment_60519 merci bcp,y a t il des livres pour les systeme de treillis(grand hangar)
Novembre 11, 201113 a comment_60743 très belle contribution, merci Mr abdeslam brahim bienvenue de nouveau karimgc :)
Decembre 17, 20195 a comment_138630 le lien de telechargement a ete supprimé vs pouver m envoyerle livre ben-chakib@hotmail.com
volume: 620 pages
taille: 36.9 Mo
format: Pdf
langue: anglaise
Bending Moment 346
11.7 Conclusion 563
bonne lecture,
