✅ Accès total aux rubriques
✅ Téléchargements illimités
✅ Expérience sans publicité
✅ Veille actus, et tendances
✅ Veille offres d'emploi
✅ Veille conférences
✅ Stockage augmenté
✅ Badge PRO
✅ Messages privés et plus !
posté par shadowmaster
RSTAB is used to
determine internal forces, support reactions and deformations of any
planar or 3D framework structure. The open and modular program concept
meets individual user demands for specific project requirements.
Following Windows standards, RSTAB has a small learning curve which
means that the user is quickly able to take advantage of the many
helpful options that the program offers.
The add-on modules make
it easier either to input data through an automated creation of
structures, loads and load combinations or to carry out further
analyses and design. For example, the CONCRETE module can be used to
design standardized reinforced concrete cross-sections for uniaxial and
biaxial bending with normal forces as well as with shear forces and
torsion, including creep and shrinkage, non-linear analyses and tension
stiffening effects.
User interface
The structural input can be carried out graphically
in a CAD-like interface as well as numerically in tables. Additionally,
there is a possibility to use the context menus by right-mouse-clicking
any item in the data navigator. The input can be permanently checked
visually by means of the photorealistic visualization of the structure
as a 3D rendered OpenGL graphic.
http://www.dlubal.de/ng1/Download.aspx? ... qjhDNz8pHW
RSTAB 6 assists you by many helpful functions to
model your structure in the most comfortable way. Additionally, various
tools are available to create routine constructions including their
loads. Member non-linearities such as yielding, tearing or slippage are
possible in the same way as tapered members, couplings non-linear
springs or eccentric connections of members.
http://www.dlubal.de/ng1/Download.aspx? ... 8c4xEufkVW
Analysis
In RSTAB 6, the calculation can be carried out
according to 1st or 2nd order theory as well as according to a large
deformation analysis (Newton-Raphson) for all member types. The results
of the load cases may be superimposed within load combinations in
order to determine the extreme values of the internal forces.
Deformations due to shear forces can be accounted for globally. At the
end of the analysis of several load constellations, a summary is issued
that informs you about the problems that may have occured during the
calculation.
http://www.dlubal.de/ng1/Download.aspx? ... +bF67UkVw3
Results and Printout
In
order to evaluate the results comfortably, they are presented in tables
that are arranged according to different criteria. By colored results
relation scales in the tables, the utilizations are immediately
visible. Different options to filter the results can reduce the number
of displayed table lines and thus improve the overview.
The results
can be documented in an adaptable printout report that is available in
different languages. The extent of this printout report can be arranged
by the user and can be saved as a template as well. It is also possible
to include automatic graphic views of the results in the printout
report.
http://www.dlubal.de/ng1/Download.aspx? ... C9yKS4rI35
Project Manager
RSTAB 6 includes a project manager with detailed information so that all
projects can be accessed in a well-organized manner. Within this
project manager, projects can be saved in a Zip file with or without
results. It represents the center of management for all Dlubal
projects.
http://www.dlubal.de/ng1/Download.aspx? ... U1/peO7tW1
Interfaces
For the integration of the structural analysis within the DP-based project
management, RSTAB 6 offers a great variety of interfaces to external
programs.
http://www.dlubal.de/ng1/Download.aspx? ... iqWDHPX1xS
Examples
http://www.dlubal.de/NG1/Download.aspx? ... wdUQjhmQ==
http://www.dlubal.de/NG1/Download.aspx? ... wZXD9H7A==
http://www.dlubal.de/NG1/Download.aspx? ... wlNtUyggUQ
http://www.dlubal.de/NG1/Download.aspx? ... De56WJGQ==
http://www.dlubal.de/NG1/Download.aspx? ... ZAI61JmA==
L'interface (comme vous allez le constater si vous l'installez) est en allemand, mais rassurez-vous il existe à l'intérieur un patch pour faire le changement en anglais. Il restera malheureusement qq modules en allemand.
liens rapidshare
http://rapidshare.com/files/25555787/Dl ... .part1.rar
http://rapidshare.com/files/25555767/Dl ... .part2.rar
http://rapidshare.com/files/25555786/Dl ... .part3.rar
http://rapidshare.com/files/25555779/Dl ... .part4.rar
http://rapidshare.com/files/25555667/Dl ... .part5.rar
ou
liens 4shared
http://www.4shared.com/file/26334004/39 ... 1.html?s=1
http://www.4shared.com/file/26335965/af ... 2.html?s=1
http://www.4shared.com/file/26337908/2d ... 3.html?s=1
http://www.4shared.com/file/26339323/65 ... 4.html?s=1
http://www.4shared.com/file/26339675/f7 ... 5.html?s=1
Si vous êtes intéressés par des didacticiels, ils en proposent dans leur site officiel:
- pour des manuels avec exemples guidés comme dans sap
http://www.dlubal.com/Download.aspx?cat ... 0873100205
- pour des videos
Ce qui est bien, c'est qu'il est compatible avec tekla structure.
bon dll à tous.
