The concrete floor slab connexion
posté par bentafat_rachid
The concrete floor slab is continuous
over the steel I-sections, and is supported by them. It is designed
to span in the j-direction in the same way as when supported by walls or
the ribs of reinforced concrete T-beams. When shear connection is provided
between the steel member and the concrete slab, the two together
span in the x-direction as a composite beam. The steel member has not
been described as a 'beam', because its main function at mid-span is to
resist tension, as does the reinforcement in a T-beam. The compression
is assumed to be resisted by an 'effective' width of slab,
http://www.zshare.net/download/3555029ef951f2/
