OmdaGéo Posté(e) le 13 mai 2008 Signaler Partager Posté(e) le 13 mai 2008 Rock Foundations File : pdf, 876 KB, 120 pages Sommaire: Chapter 1 Introduction Chapter 2 Design Considerations Design Approach Types of Structures Design Considerations Factor of Safety Chapter 3 Site Investigations Applicable Manuals Section I Preliminary Studies Map Studies Other Sources of Information Field Reconnaissance Section II Field Investigations Geologic Mapping Geophysical Explorations Borings Exploratory Excavations In-SituTesting Section III Laboratory Testing Selection of Samples and Tests Laboratory Tests Chapter 4 Rock Mass Characterization Intact Rock versus Rock Mass Section I Geologic Descriptions Rock Core Descriptors Supplemental Descriptors Index Tests Section II Rock Mass Classification Section III Shear Strength Rock Failure Characteristics Failure Criteria Shear Strength Tests Shear Strength Testing Program Section IV Deformation and Settlement Moduli Definitions Test Methods for Estimating Modulus Other Methods for Estimating Modulu Considerations in Selecting Design Modulus Values Selection of Design Moduli Section V Use of Selected Design Parameters Chapter 5 Deformation and Settlement Section I Categories of Rock Mass Deformation Time-Dependent Deformations Time-Independent Deformations Section II Analytical Methods Closed Form Methods Numerical Models Section III Allowable Settlement Mass Concrete Structure SectionIV Treatment Methods Rock Mass Improvement Foundation Design Modifications . Chapter 6 Bearing Capacity Section I Failure Modes Intact Rock Mass Jointed Rock Mass Layered Rock Mass Highly Fractured Rock Masses Secondary Causes of Failure Section II Methods for Computing Bearing Capacity Analytical Methods Bearing Capacity Equations Eccentric Load on a Horizontal Foundation Section III Allowable Bearing Capacity Value Structural Limitations Section IV Treatment Methods Effective Unit Weight Foundation Depth Chapter 7 Sliding Stability Section I Modes of Failure Potential Failure Paths Section II Methods of Analysis General Approach Conditions for Stability Assumptions Analytical Techniques for Multi-Wedge Systems Seismic Sliding Stability Factor of Safety Section III Treatment Methods Increase in Shear Strength Increase in Passive Wedge Resistance Lateral Restraint Chapter 8 Cut Slope Stability Section I Modes of Failure Additional Factors Influencing Slope Stability Section II Methods for Assessing Stability Sliding Stability Analyses Toppling Stability Analyses Localized Sloughing Analyses Physical Modeling Techniques Section III Treatment Methods and Planning Considerations Chapter 9 Anchorage Systems SectionI Modes of Anchor-Rock Interaction Tensioned Anchor Systems Untensioned Anchor Systems SectionII Methods of Analysis Analyses for Tension Anchor Systems Dowels Chapter10 Instrumentation Section I Program Initiation Cost Control Types and Number of Instruments Section II Cut Slope Instrumentation Foundation/Structure Instrumentation Section III Types of Instruments and Limitations Piezometers Ground Motions/Vibrations Limitations Section IV Data Interpretation and Evaluation Reading Frequency Automatic Data Acquisition Systems Chapter 11 Construction Considerations Section I Excavation Information Requirements Excavation Methods Effects of Discontinuitieson Excavation SectionII Dewatering and GroundWater Control Dewatering Methods Section III Ground Control Stability Through Excavation Planning Selection of Stabilization Measures Stabilization Methods Section IV Protection of Sensitive Foundation Materials Common Materials Requiring Protection Determination of Protection Requirements Foundation Protection Methods Section V Excavation Mapping and Monitoring Construction Monitoring Chapter 12 SectionI Karst,Pseudokarst,and Mines Cavitiesin Rock Investigations Alternative Solutions Section II Swelling and Squeezing Rock Rebound Cation Hydration Chemical-Reaction Swelling Loss of Internal Strength Frost Action Section III Soil-Rock Contacts Weathering Profiles Design Considerations in Weathering Télécharger :contrac: : Rock Foundations.pdf[/attachment:1jbftsv5] Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chtaran Posté(e) le 4 février 2009 Signaler Partager Posté(e) le 4 février 2009 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
