comment_13837
http://www.2shared.com/file/3474974/fb2e45ba/EC2.html
1. ASSOCIATION ACIER
2. LONGUEUR D’ANCRAGE
3. JONCTION DE BARRES PAR RECOUVREMENT ; COUPLEURS
4. ANCRAGE ET REGROUPEMENT D'UN GROUPEMENT DE BARRES
5. LONGUEUR DES CADRES, ETRIERS, EPINGLES
1. LES POUTRES
2. ANALYSE STRUCTURALE, METHODES DE CALCUL PERMETTANT DE DETERMINER LES SOLLICITATIONS ( MOMENT DE FLEXION, EFFORT TRANCHANT )
3. CAS DE CHARGEMENT
4. ÉVALUATION DES CHARGES TRANSMISES PAR LE HOURDIS AUX POUTRES DE BORDURE ET DES POUTRELLES AUX POUTRES
5. ÉTUDE DES DALLES
6. LES APPUIS DE RIVE ET INTERMEDIAIRES
7. TRACTION SIMPLE - LES TIRANTS
8. COMPRESSION SIMPLE - LES POTEAUX
9. CALCUL DES SEMELLES FILANTES ET RECTANGULAIRES SOUS CHARGE CENTREE
10. MURS DE SOUTENEMENT (ANALYSE DE LA STABILITE)
11. JOINTS DE DILATATION
12. CHAINAGES
13. VOILES
1. HYPOTHESES
2. JUSTIFICATION VIS A VIS DE L'E.L.U.R. DES PIECES PRISMATIQUES SOUMISES A DES SOLLICITATIONS TANGENTES
3. MODELISATION:(TREILLIS DE RITTER-MÖRSH)
4. PRISE EN COMPTE DU BETON
5. PRINCIPES DE VERIFICATION A L’EFFORT TRANCHANT
6. DISPOSITIONS CONSTRUCTIVES RELATIVES AUX ARMATURES D’EFFORT TRANCHANT
7. NOTATIONS UTILISEES
8. ÉLEMENTS NE NECESSITANT PAS D’ARMATURES D’EFFORT TRANCHANT
9. ÉLEMENTS POUR LESQUELS DES ARMATURES D’EFFORT TRANCHANT SONT REQUISES EFFORT TRANCHANT RESISTANT
10. ORGANIGRAMME DE CALCUL DES ARMATURES D’EFFORT TRANCHANT EN FLEXION SIMPLE
11. POUR UN EFFORT TRANCHANT MODERE, ORGANIGRAMME SIMPLIFIE DE CALCUL DES ARMATURES TRANSVERSALES EN FLEXION SIMPLE
12. TRANSMISSIONS DIRECTES
13. DETERMINONS LE DIAGRAMME ENVELOPPE DE L’EFFORT TRANCHANT (APPLICATION NUMERIQUE)
14. LES APPUIS DE RIVE ET INTERMEDIAIRES
15. LES SUSPENTES A PREVOIR AU NIVEAU DES APPUIS INDIRECTS
16. CISAILLEMENT LE LONG DES SURFACES DE REPRISE
17. CISAILLEMENT A LA JONCTION AME-MEMBRURES
18. ANNEXES
1. SITUATION DE PROJET
2. COMBINAISONS FONDAMENTALES
3. BETON ELU
4. CARACTERISTIQUES DES ACIERS DU BETON ARME
5. CLASSES D’EXPOSITION EN FONCTION DE L’ENVIRONNEMENT
6. REGLE DES 3 PIVOTS
7. PROCEDURES DE CALCUL
8. DEMARCHE DE PROJET
9. ORGANIGRAMME DE CALCUL DES ARMATURES LONGITUDINALES EN FLEXION SIMPLE, SECTION RECTANGULAIRE
10. LONGITUDINALES EN FLEXION SIMPLE, SECTION RECTANGULAIRE
11. EPURE D'ARRET DE BARRES
12. DETERMINATION DES ARMATURES TRANSVERSALES DROITES: METHODOLOGIE
13. ORGANIGRAMME DE CALCUL DES ARMATURES D’EFFORT TRANCHANT EN FLEXION SIMPLE
14. POUR UN EFFORT TRANCHANT MODERE, ORGANIGRAMME SIMPLIFIE DE CALCUL DES ARMATURES TRANSVERSALES EN FLEXION SIMPLE
15. ORGANIGRAMME SIMPLIFIE DE CALCUL DES ARMATURES TRANSVERSALES (BTS)
16. DONNEES POUR UN SUJET U 4.1
17. VERIFICATIONS
18. MAITRISE DE LA FISSURATION
19. L’ASPECT REGLEMENTAIRE DE LA MAITRISE DE LA FISSURATION
20. ÉTATS LIMITES DE DEFORMATION
21. ELS NOTATIONS
22. EXPRESSION DU MOMENT QUI PROVOQUE LA FISSURATION
23. EXPRESSION DES CONTRAINTES LORSQUE M>Mcr
24. EXEMPLE : CALCUL SECTION DROITE D’UNE POUTRE
1. UTILISATION DES FORMULES DE BRESSE
2. INTEGRATION PARABOLIQUE DE SIMPSON
3. CALCUL DE LA COURBURE : 1ERE METHODE
4. AUTRE METHODE DU CALCUL DE LA COURBURE
5. METHODE DE CALCUL DE LA FLECHE DANS UNE SECTION DROITE
6. CALCUL DE LA FLECHE DANS LA SECTION MEDIANE D’UNE TRAVEE ISOSTATIQUE CHARGEE UNIFORMEMENT
7. CALCUL DE LA FLECHE DANS LA SECTION MEDIANE D’UNE TRAVEE ISOSTATIQUE CHARGEE UNIFORMEMENT
8. CALCUL APPROCHE
9. JUSTIFICATION PARTIELLE : DEFORMATION AU NIVEAU DE L’ACIER
10. ÉTAT LIMITE DE DEFORMATION ASPECT REGLEMENTAIRE
11. CALCUL DU FLUAGE SELON L’ANNEXE B DE L’EC2
12. MODULE D’ELASTICITE LONGITUDINALE OU MODULE D’YOUNG ET COEF. D’EQUIVALENCE EFFECTIF
1. FLEXION SIMPLE - POUTRE EN T - DETERMINATION DES ARMATURES LONGITUDINALES
2. EXEMPLE : CALCUL SECTION DROITE D’UNE POUTRE EN T SANS ARMATURES COMPRIMEES ACIER S500 CLASSE B DIAGRAMME ELASTO-PLASTIQUE PARFAIT
3. EXEMPLE : CALCUL SECTION DROITE D’UNE POUTRE EN T SANS ARMATURES COMPRIMEES ACIER S500 CLASSE B DIAGRAMME ELASTO-PLASTIQUE PARFAIT
1. HYPOTHESES
18. ANNEXES
SOURCE : CERPET
  • Réponses 7
  • Vues 11.4k
  • 8 mois après...
  • 1 an après...
  • 4 semaines après...
