Invité Posté(e) le 24 février 2008 Signaler Partager Posté(e) le 24 février 2008 posté par bentafat_rachid Fundamentals of Earthquake Engineering 1.1 Introduction This chapter provides a basic understanding of earthquakes, by first discussing the causes of earthquakes, then defining commonly used terms, explaining how earthquakes are measured, discussing the distribution of seismicity, and, finally, explaining how seismicity can be characterized. Earthquakes are broad-banded vibratory ground motions, resulting from a number of causes including tectonic ground motions, volcanism, landslides, rockbursts, and man-made explosions. Of these, naturally occurring tectonic-related earthquakes are the largest and most important. These are caused by the fracture and sliding of rock along faults within the Earth’s crust. A fault is a zone of the earth’s crust within which the two sides have moved — faults may be hundreds of miles long, from one to over one hundred miles deep, and are sometimes not readily apparent on the ground surface. Earthquakes initiate a number of phenomena or agents, termed seismic hazards, which can cause significant damage to the built environment — these include fault rupture, vibratory ground motion (i.e., shaking), inundation (e.g., tsunami, seiche, dam failure), various kinds of permanent ground failure (e.g., liquefaction), fire, or hazardous materials release. In a particular earthquake event, any particular hazard can dominate, and historically each has caused major damage and great loss of life in particular earthquakes. For most earthquakes, shaking is the dominant and most widespread agent of damage. Shaking near the actual earthquake rupture lasts only during the time when the fault ruptures, a process that takes Charles Scawthorn Department of Urban Management, Kyoto University, Kyoto, Japan 1.1 Introduction ................................................... 1-1 1.2 Causes of Earthquakes and Faulting ..................... 1-2 1.3 Measurement of Earthquakes 1-5 Magnitude Intensity Time History Elastic Response Spectra Inelastic Response Spectra 1.4 Distribution of Seismicity .................................. 1-20 1.5 Strong Motion Attenuation and Duration ............. 1-21 1.6 Characterization of Seismicity ............................. 1-26 Glossary................................................................. 1-28 References .............................................................. 1-30 Further http://www.zshare.net/download/714694273a4569/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) le 7 mars 2008 Signaler Partager Posté(e) le 7 mars 2008 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
