progeCAD is a computer aided 2D & 3D design program. It's based on the IntelliCAD engine which just happens to be one of AutoCAD's most powerful challengers. Because AutoCAD is the most widely used professional CAD software on the market today, anything that competes in AutoCAD's sandbox has to be able to not only vie for attention in a difficult and entrenched environment, but also provide some incentives to move off the industry standard. ProgeSOFT is a serious company with a serious CAD product and offers extensive technical product support, so we decided to give progeCAD a heavy duty test. We reviewed progeCAD over a two month period in a busy architectural and industrial design studio. The results may surprise you.
progeCAD 2008, a complete 2D/3D CAD powered by the most recent IntelliCAD 6.4 engine, is the next step of IntelliCAD and an easy replacement for AutoCAD® and AutoCAD LT®! progeCAD 2008 contains many important new features and enhancements to offer all the customers an unparalleled stability and speed.
progeCAD 2008 Professional is CAD software highly compatible with industry standards, such as AutoCAD DWG v2.5 through 2008, “AutoCAD Like” menus, SHX and TrueType fonts, AutoLISP, AutoCAD blocks, etc. Sold at a fraction of the cost of most AutoCAD software, progeCAD 2008 Professional, powered by IntelliCAD, is a logical choice for drafters, designers, engineers, architects, anyone needing AutoCAD compatible software.
progeCAD has already won the loyalty of many users with robust features like DWGT / DXFT / DWFT 2007 support, Polar Tracking, eSnap (like oSnapT), PDF import / export, raster to vector support, advanced hatching and more - all at a very low price. Now progeCAD 2008 offers important new additional features.
Features: Advanced Render, Raster, Vectorializer, ACIS Solids, PDF-DWF™-JPG Printing, PDF to DWG Import, Layout tabs, Express Tools, Polar Tracking, Refedit ALE module and Libraries.
Three customization languages (Lisp, C++ and VBA) direct access to the object automation via COM interface
Includes four blocks Libraries (Architectural, Mechanical, Electrical components and 3d Furnishings)
First and foremost, progeCAD is a serious tool. Second and no less important, the user interface and menu layout are very similar to AutoCAD, so if you're coming from that world, progeCAD will be easy to get to know. Throughout general project use, progeCAD seemed stable. Because it also offers a familiar layout, getting up and running at full speed with the software took only a couple of days. The organization behind the IntelliCAD engine is unique in the computer-aided design industry, consisting of a consortium to update the source code and provide some marketing support, and members who sell the software on a nonexclusive basis. The common goal is to create something that is powerful, less expensive than industry giant AutoCAD, and of course fully compatible with AutoCAD DWG files. Because it's the first question asked by anyone who is asked to consider an AutoCAD alternative, the very first issue we addressed at the beginning of the review period was DWG compatibility. I'm happy to report that compatibility is generally excellent.
progeCAD 2008:
* reads and writes AutoCAD® DWG files from 2.5 to 2008, the files you work with everyday!
* has industry standard AutoCAD Commands
* has AutoCAD Menu, Script, Font Compatibility
* has AutoLISP® Compatibility! Works with images (Insertion and Visualization)
* has Advanced Rendering Options
* is built with ACIS® Solid Modeling included
* can import and edit your Raster Images
* has Express Tools
* export to PDF and JPG
* convert from PDF to DWG
* comes with near 10,000 standard symbols and blocks
* supports RedLine and Markup made by progeCAD Viewer DWG
What's New in progeCAD 2008:
- AutoCAD 2008 DWG files support.Read and Write without convertion all DWGs format from v. 2.5 to 2008
- Quick Save and Open. Best performance opening and saving drawings. Improved large files support
- eTransmit. utility for gathering, compacting and transmitting an DWG file
- Snap 'From'. The smart Snap option completing snap's family
- Advanced Refedit (Block In-Place Editing). Edit locally individual objects within a Block. 'Save as' supported to make a copy of original
- True Color support. Go ahead the limit of 256 colors in drawings
- Create Wipeout entities. Hide part of a drawing that is included in the main drawing
- Plot Interface improved. AutoCAD® style with memorization of previous settings
- Improved Asiatics fonts support. Chinese, Korean and Japanese improved compatibiliy and new fonts
- DWGCODEPAGE system variab. Assign a character set to a drawing. Better drawings interchange
- Hidden Lines in Dview (perspective views). Hide lines now working in perspective
- Find & Replace. Find and replace text and block attributes in DWGs
- Improved GUI. New robust menu structure
- Software Updater. the availability of software upgrades are automatically checked and proposed for download
- New raster engine. Best performance and support of edit Grips. PNG file format supported
- ECW (Enhanced Compression Wavelet) support. An open standard wavelet compression image format developed by Earth Resource Mapping.
- Jpeg 2000 image support. Jpeg 2000 is a wavelet-based image compression standard.
- Lock Layout Viewports. Lock the model space view or location while panning or zooming in paper space
- Export DWF 3D. New 3D format for DWF supported
- Entity dependent content menu. Content menu provide commands shortcuts related to the selected entity
- Fast layout management. Quick regen on viewports
- DWG 2007/2008 native support. Latest DWG version don't need convertion process. Better compatibility
- New system variables. Dozen of new DWG variables supported
- Windows Vista. Improved integration and support
- Improved Xref support. Xref layers available in the layers dropdown
- Improved print GUI. Redesigned print Form AutoCAD® like
- Improved Re-register license system. Transfer the software license to another PC more easier (Also after a disk format)
progeCAD 2008 Professional 8.0.18.2
197 MB | RS Link
progeCAD 2008:
* has Express Tools
- Bug Fixes. Hundreds of bug fixes
http://www.rapidshare.com/files/145421972/progeCADPro8.0.18.18_www.SoftArchive.Net.rar
