all the same[/TD] [TD]malgré tout, quand même[/TD][/TR] [TR] [TD]after all [/TD] [TD]après tout[/TD] [/TR] [TR] [TD]Also, ... [/TD] [TD]De plus, ... / De même, ... (préférer : moreover)[/TD][/TR] [TR] [TD]and[/TD] [TD]et[/TD] [/TR] [TR] [TD] as a consequence[/TD] [TD]en conséquence, par conséquent[/TD][/TR] [TR] [TD] as a matter of fact[/TD] [TD]en fait[/TD] [/TR] [TR] [TD] as a result[/TD][TD]en conséquence[/TD] [/TR] [TR] [TD] besides[/TD] [TD]d’ailleurs[/TD] [/TR] [TR] [TD]but[/TD][TD]mais[/TD] [/TR] [TR] [TD]by the way[/TD] [TD]soit dit en passant[/TD] [/TR] [TR] [TD]despite[/TD][TD]malgré[/TD] [/TR] [TR] [TD] either ... or ...[/TD] [TD]soit... soit ...[/TD] [/TR] [TR] [TD]eg / e.g.[/TD][TD]par exemple[/TD] [/TR] [TR] [TD]... , for ... [/TD] [TD]..., car ....[/TD] [/TR] [TR] [TD]for all that[/TD][TD]malgré cela[/TD] [/TR] [TR] [TD]furthermore[/TD] [TD]en outre, de plus[/TD] [/TR] [TR] [TD]hence[/TD][TD]d’où[/TD] [/TR] [TR] [TD]however[/TD] [TD]cependant, toutefois[/TD] [/TR] [TR] [TD]ie / i.e.[/TD][TD]c’est-à-dire[/TD] [/TR] [TR] [TD]if not[/TD] [TD]sinon[/TD] [/TR] [TR] [TD]in addition[/TD][TD]de surcroît[/TD] [/TR] [TR] [TD]in any case[/TD] [TD]en tout cas[/TD] [/TR] [TR] [TD]in/by comparison[/TD][TD]par comparaison[/TD] [/TR] [TR] [TD]in/by contrast[/TD] [TD]par opposition[/TD] [/TR] [TR] [TD]in effect[/TD][TD]dans la réalité[/TD] [/TR] [TR] [TD]in fact[/TD] [TD]en fait[/TD] [/TR] [TR] [TD]in other words[/TD][TD]en d’autres termes[/TD] [/TR] [TR] [TD]in spite of...[/TD] [TD]malgré...[/TD] [/TR] [TR] [TD]in that case[/TD][TD]dans ce cas[/TD] [/TR] [TR] [TD] in the first place, in the second place, [/TD] [TD] en premier lieu, en second lieu, [/TD] [/TR] [TR] [TD]in the same way[/TD][TD]de même[/TD] [/TR] [TR] [TD]in this case[/TD] [TD]dans ce cas[/TD] [/TR] [TR] [TD]instead of[/TD][TD]au lieu de[/TD] [/TR] [TR] [TD]moreover[/TD] [TD]en outre, de plus[/TD] [/TR] [TR] [TD]nevertheless / nonetheless[/TD][TD]néanmoins[/TD] [/TR] [TR] [TD]notwithstanding[/TD] [TD]nonobstant[/TD] [/TR] [TR] [TD]on the contrary[/TD][TD]au contraire[/TD] [/TR] [TR] [TD]on the one hand ... on the other hand ... [/TD] [TD]d’une part ..., d’autre part ...[/TD] [/TR] [TR] [TD]or rather[/TD][TD]ou plutôt, ou mieux, ou plus exactement[/TD] [/TR] [TR] [TD]otherwise[/TD] [TD]sinon, mais par ailleurs[/TD] [/TR] [TR] [TD]over and above[/TD][TD]par dessus le marché[/TD] [/TR] [TR] [TD]that is to say [/TD] [TD] c’est-à-dire[/TD] [/TR] [TR] [TD]then[/TD][TD]alors[/TD] [/TR] [TR] [TD]thereby [/TD] [TD]de ce fait,[/TD] [/TR] [TR] [TD]therefore[/TD][TD]par conséquent[/TD] [/TR] [TR] [TD]this is why[/TD] [TD]c’est pourquoi[/TD] [/TR] [TR] [TD]though[/TD][TD]malgré tout[/TD] [/TR] [TR] [TD]thus[/TD] [TD]par conséquent[/TD] [/TR][TR] [TD]to this end[/TD] [TD]à cet effet[/TD][/TR][/TABLE]
Voici les mots de lianson utiles en anglais :
[TABLE][TR] [TD]
