Invité Posté(e) le 24 février 2008 Signaler Partager Posté(e) le 24 février 2008 posté par bentafat rachid Concrete made with portland cement is widely used as a construction material because of its many favorable characteristics. One of the most important is a large strength-cost ratio in many applications. Another is that concrete, while plastic, may be cast in forms easily at ordinary temperatures to produce almost any desired shape. The exposed face may be developed into a smooth or rough hard surface, capable of withstanding the wear of truck or airplane traffic, or it may be treated to create desired architectural effects. In addition, concrete has high resistance to fire and penetration of water. But concrete also has disadvantages. An important one is that quality control sometimes is not so good as for other construction materials because concrete often is manufactured in the field under conditions where responsibility for its production cannot be pinpointed. Another disadvantage is that concrete is a relatively brittle material—its tensile strength is small compared with its compressive strength. This disadvantage, however, can be offset by reinforcing or prestressing concretewith steel. The combination of the two materials, reinforced concrete, possesses many of the best properties of each and finds use in a wide variety of constructions, including building frames, floors, roofs, and walls; bridges; pavements; piles; dams; and tanks http://www.zshare.net/download/3676748ea50564 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
