comment_249453
There are two kinds of asphalt plants, one is asphalt batch mix plant, the other is asphalt drum mix plant. The former produces asphalt mixture batch by batch; the latter can continuously produce asphalt mixture uninterruptedly. Therefore, in some countries or regions, asphalt batch plant is also called the intermittent asphalt plant, and asphalt drum mix plant is also called the continuous asphalt plant.
Asphalt batch mix plant is widely used now due to high quality asphalt mixture, while asphalt drum plant has high cost-effectiveness, and can be applied to a large number of low-grade roads in towns and villages.
How To Make a Choice Between Asphalt Batch Mix Plant and Asphalt Drum Mix Plant?
If the project is large in scale, high in grade, or needs to change oil-stone ratio in operation, asphalt batch mix plant is supposed to be a good choice.
If the project scale is small, the grade is low, and environmental protection requirements are not very high, asphalt drum mix plant is probably the best choice.
Take project requirements and project budget in consideration and select asphalt batch mix plant or asphalt drum mix plant customized for you. For example, you can demand to add one more baghouse dust collector to the asphalt drum plant or add recycling and utilization system to asphalt batch mix plant, etc.
  • Vues 32
