nour007 Posté(e) le 16 avril 2009 Signaler Partager Posté(e) le 16 avril 2009 Before You Download Before downloading and installing: Read this http://images.autodesk.com/adsk/files/r ... e_2010.pdf Get Started Read all instructions above then click on the following link to download the executable file. Autodesk Revit Structure 2010 (exe – 1.8 GB http://revit.downloads.autodesk.com/dow ... ST2010.exe Notes * The executable file contains both 32 and 64-Bit versions of Autodesk Revit Structure 2010. * The executable file can be applied to both the standalone and Suite versions of Autodesk Revit Structure 2010. * Downloads are applicable to licenses under subscription or for trial or demo licenses for non-subscription users, worldwide. * Files saved in new releases of this product are not compatible with previous releases. However, files saved in the same release are compatible across different build numbers. * Microsoft® Internet Explorer® 6 (SP1 or later) is required. * For problems downloading or installing Autodesk Revit Structure 2010 and for general information or questions, contact Autodesk Product Support (Autodesk® Subscription login required). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
