comment_38957
salut à tte l'equipe
j'ai un probleme a l execution de arch 16.1 lordinateur se plot et me sort un message voir si dessous) je me trouve obliger de le metre sous tension et le redemarrer;
voila le message
A problem has been detected and windows has been shut down to prevent ..to your computer
Bat-pool-caller
If this is the first time you’ve seen this stop error screen restart your computer
If this screen appears again follow these steps:
- check to make sure any new hardware or software is properly installed.
If this is a new installation ,ask your hardware or software manufacturer for any windows updates you might need.
- if problems continue, disable or remove any newly installed hardware or software .
Disable BIOS memory options such as caching or shad wing.
If you need to use safe mode to remove or disable components, restart your computer press F8 to selected advanced startup options and then selected safe mode
  • Vues 1.9k
comment_39023
The guy Hassan is right.
Hasp versions stop at win XP.
New hasp for vista is required. Perhaps wait for Win7 and ask Graitec to supply correct hasp driver compatible with Win Vista/ Win7
